Good morning all,
I'm struggling to figure out if I'm doing something wrong, or if TILOS just isn't responding correctly. I have a couple sector profiles that I'm trying to display as distance scales. One uses the distance scale from the Integrated View Range, and another uses an equation to calculate the relative distance scale for it to be positioned on the view. The equation seems to be properly calculating the relative distance in the sector profile, however when I try to display this sector profile, no combination of options that I have tried will display the items in the sector profile.
The view range for this display is between 200+000 and 213+000
Sector Profile w/ Equation Applied calculating Relative Distances within the Range
Distance Line Scale Properties
I've tried various combinations of View Range / Zero-Point (from -100+000 to +300+000) and Equation Options checkbox options, and I still cannot see any of the items in the sector profile. I've even turned off the equation in the sector profile and tried to adjust the zero-point and view range there.
The only thing I can think is that maybe I'm using the equation properties incorrectly, however that is working to generate the expected Relative distance in the sector profile item distances, so I'm stumped there as well.
Anyone have a similar situation that they've managed to solve.
Thanks in advance,
Ryan
