 Issue with Isolate/Show Function across multiple IFC models
Natalya Shin's profile image
Natalya Shin posted 06-26-2026 04:03
I created a group in the Organizer that contains two different models (IFC files). When I isolate an object from one model and then try to show (unhide) an object from the other model, the object does not appear.
However, when I enable Ghost Mode, I can see all objects from both models. Also, if I first isolate several objects from both models and then try to show additional objects from the corresponding models, it works as expected.
Could this be a software bug?
Is there a way to isolate objects from one model and, within the same view, unhide objects from another model?
Thank you in advance.
