 Rotate model over horizontal axis
Paulius Vasiliauskas's profile image
Paulius Vasiliauskas posted 06-29-2022 04:45
Hi ,
Is it possible somehow to rotate object over horizontal axis?
Cause most of the tall objects witch are placed on a building like columns are modeled vertically.
But manufacturing process is made horizontally. To manufacture the element it is easier to see it laid down on one side.
So any options now to make this rotation ?
Or where could i submit this feature request , as i couldn't find a right place to do this.
Darshan Rajaram Kamat
Hi Paulius,
Rotating around a horizontal axis is not available in Trimble Connect 3D Viewer. You can check if  "Look around" feature helps your use case.  You can submit feature requests to our Support team (connect-support@trimble.com).
Darshan Kamat
