Yes , that is the datum, however the project is defined in GDA2020 and that is what I am using.
Got it going today with RTX but had to place the model manually on control points and hopefully I will be able to apply the same json file for all other models within the project.
Problem with Australia is that it is constantly moving North East of about 70mm/year so it is just easier to use local CORS base station setup over the control point, at least everything ties in within the project.
Pawel
