 Trimble Connect Clash with .trb files
Thomas NOYON's profile image
Thomas NOYON posted 06-29-2022 02:27
Recently I've been trying to get the Trimble Connect clash module to work with .trb files exported from Quadri and it doesn't detect any clash even though there are a few that are clearly visible.
Is it actually possible to detect clashes between .trb files ? If yes then how should I configure the quadri 3D presentation that I export as trb to make sure the clashes get detected ? I am using a custom feature catalogue for the project, I'm not sure if this has anything to do with how the geometry is store.
Regards,
Thomas Noyon
Ole Christian Eidhammer's profile image
As you have seen, clash detection does not support TRB with objects from civil construction ==> Use IFC files instead.
