 Trimble Connect crashes when I right-click on a view
Jelle de Jong's profile image
Jelle de Jong posted 06-26-2025 22:45
Since the last version (1.25.3.660), whenever I add a view and try to right-click it to update the view or to delete it, Trimble Connect crashes.
In the event viewer the following error appears: (text has been translated)
Name application with error: TrimbleConnect.exe, version 1.25.3.660, timestamp: 0x99769d82
Name module with error: clr.dll, version 4.8.9310.0, timestamp: 0x67db4f32
Path to application with error: C:\Program Files\Trimble\Trimble Connect\TrimbleConnect.exe
Path to module with error: C:\Windows\Microsoft.NET\Framework64\v4.0.30319\clr.dll
Any idea what's wrong?
Jari Juntunen's profile image
Jari Juntunen
Hello Jelle,
Based on the error description, there may be a problem with your computer operating system. The path to module with error points to the Windows system files related to the Microsoft .NET Framework. Often it helps to ensure that the latest Windows and .NET updates are installed in your computer. If the problem persists, you can reach out to the Trimble Connect technical support team (connect-support@trimble.com).
With regards,
Jari
Emile van Hoogstraten's profile image
I get the same crash, with a similar crash report (Dutch) Only my crash report oint to the file System.Core.ni.dll
Toepassingsnaam met fout: TrimbleConnect.exe, versie: 1.25.3.660, tijdstempel: 0x99769d82
Naam van foutmodule: System.Core.ni.dll, versie: 4.8.9297.0, tijdstempel: 0x6758e5b2
Uitzonderingscode: 0xc00000fd
Foutoffset: 0x000000000035b8f9
Foutproces-id: 0x4904
Begintijd van foutieve toepassing: 0x1DBF61E0CBA1FF9
Faulting-toepassingspad: C:\Program Files\Trimble\Trimble Connect\TrimbleConnect.exe
Faulting-modulepad: C:\WINDOWS\assembly\NativeImages_v4.0.30319_64\System.Core\cf9616e40d9e7e4d682f88f6d5725156\System.Core.ni.dll
My PC has the latest windows updates installed!
Jelle de Jong
With the latest update (1.26.0.672), this error has been resolved.
