I'm using Trimble Connect Sync, syncing with a local folder, but when I delete a file from the local folder and sync it reappears in Trimble Connect. It's set to bi-directional, is there a setting to erase from local?
Hi Felipe,Please use the Local transfer mode if you want the local machine folder hierarchy to reflect in Connect server. I have replied to your other post too with details.
Darshan Kamat
