Hi, I have just installed the Trimble Connect Visualizer extension and tried to render an interior model of a house. I have selected different colors and textures for many of the surfaces in the house. When I render it, the surfaces glitch out and turn white depending on what angle I am viewing from. Pictures attached for reference. Is there something I'm doing wrong? I have messed with all the settings in the Visualizer and not found a solution. Please let me know, thanks.
Update: I have discovered that all the surfaces that glitch out have a white backside. When I turn the backside to the same color as the front, it no longer glitches. However, this would be an extremely tedious and time consuming solution, surely there is another way to solve the issue?
