I have a TSC7 (gen1) with 64GB internal storage (C-Drive). I have an additional 250GB SD card inserted (D-Drive)
My issue is I don't have enough free space on C-Drive to have multiple Trimble Access projects that involve scanning. After Trimble Access, Windows 10 pro, and Adobe are installed on the TSC7 there was originally 10GB spare, however over the last 2 years that has gradually reduced to 4GB I suspect this is from windows updates not completely cleaning up behind themselves. I've done a disk clean-up, deleted all tempory files, deleted some bloatware and un-critial software (outlook etc)
Trimble Access maps projects to C:ProgramData:Trimble:Trimble Data:Projects but I really need this to be on the D drive. Trimble support said this isn't possible "TA cannot use the SD external memory card for the job file root directory. It allows you only to create folders & store survey job under the \Trimble Data folder. Trimble Access must work on the (C:) Drive, it won't work on other locations".
Is there a workaround for this to remap this or any large delectable windows files I might of overlooked? Otherwise the 64GB TSC7 is basically useless?
Regards & TIA,
Lachlan
