 Uploading Revit file in 3D viewer web
Jonathan Morin's profile image
Jonathan Morin posted 08-18-2022 12:19
When I upload a revit file in the 3D viewer web, the conversion is very long VS when I use the desktop version. Is it normal?
Also, that would be useful to have the progress of the conversion (in %) in the web version, like the one there is on the desktop version.
Thanks!
Roger Ng's profile image
Roger Ng
Converting RVTs through the Trimble Connect Web importer does not work very well. You may try Trimble Connect Desktop. Sometimes it works.. or use the Revit Add-In
Here are some references:
https://docs.revit.connect.trimble.com/
https://community.trimble.com/viewdocument/supported-files#MainCopy_ctl10_lblIsPinned
