 Viega Copper Reducers not processing
Dan Berger's profile image
Dan Berger posted 05-05-2023 05:52
Good Morning All,
the Viega Copper Propress fittings are not processing.  When I model a 3/4" to 1/2" or even 1 1/2" to 1 1/4" copper piping all the fittings will process except the reducer.  If I select the pipes connected to the reducer and the reducer and convert it, it does nothing.  If I select just the reducer and convert it, it does nothing.  This just started happening after the last update.  If I change to a different copper press system like Apollo I do not get these issues.
Does anyone know of any work arounds outside of manually loading the fitting, changing the sizes and then connecting it to the nodes?
Thanks
Dan
