Joel Cusick
Installing the USB Switcher App - DETAILED Support Doc
Discussion created by Joel Cusick on Apr 10, 2020
This PDF and supporting Powerpoint file are intended to provide step-by-step instructions for installing USB SWITCHER APP on applicable Trimble receivers. Once a compatible Trimble has been properly switched using this App, the device can continue to use the data transfer utility in either Pathfinder Office or Positions for expedient file management.
We found in our user community there was quite a bit of trouble getting this switcher to work using online documentation and during our development of this document we found this also works on TSC3 survey controllers.  Steps for manual connection to the SD card for 2008/3000 Geo's is also included.
Please feel free to use.  Contact me if you want the word doc version.
Be aware some links will not work for the Public due to being inside the Federal Govt. sphere.
on June 9, updated attachment to most recent file.   Word Docx format so editing may occur.
Good Luck.
