Point Symbols Not by Points in Sheet View
Question asked by Ben Wall on May 14, 2020
Latest reply on May 14, 2020 by Richard Tyndall
I seem to be having an issue with my point symbols not showing up beside the label/point location when I create my sheet views. It seems to be linked to my dynaview being at an angle and not perpendicular to the CAD file's alignment.  See below.  The first is with the dynaview at an approximate 50 deg angle and the second is at a 0 deg angle.  Both are the exact same sheet template with the only change being the dynaview selected.
I've been printing using the second option while I tried to find a solution, but have been required to use larger scales (80 to 100) to capture everything where a smaller scale would have worked better if I could have rotated the dynaview.  If anyone has seen this in the past and can let me know how to fix it I would be most appreciative.  THANKS!
