Why will one Revit family, with embedded Markers, not populate Field Points?
Question asked by Guest on May 21, 2020
Hello!
We have two Revit Families with Markers embedded. Field Points are able to be populated for one of them using "Place Points over Markers". The second family gives the error, "System.NullReferenceException: Object reference not set to an instance of an object...."
Has anyone had a similar issue and found a solution? We have been trying to back engineer from the working family to figure out the difference between the two. Have not found yet.
Appreciate any insight you have.  Thanks!
