Issue Connecting to SP80 Receiver Using R-Series Driver
Question asked by Charles Bisbee on Jun 16, 2020
Latest reply on Jun 17, 2020 by Charles Bisbee
I am using the Xamarin TPSDK for Catalyst version 2020.0.82.19504 to connect to Trimble and Spectra Precision receivers. Using the R-Series driver I am successfully connecting to Trimble R-Series receivers in our mobile app and pulling in all the expected GNSS observations. However, as referenced in the answer in this post Trimble Receiver Naming Convention, I should be able to use the R-Series driver to connect to Spectra Precision devices. Currently I am unable to make the connection to the SP80 receiver I have which is running firmware version 3.46. When I go to connect I get an exception saying "Could not connect, the receiver is not supported (1)". Below is a snippet from the log file generated from our app.
TrimbleBluetoothCommunicatorDroid.BTListenerThread:  bt socket closed, read return: -1
TrimbleBluetoothCommunicatorDroid.Disconnect:  BT listener thread terminated
TrimbleBlutoothCommunicatorDroid.Disconnect:  Bluetooth communicator disconnected
TrimbleCatalystManagerDroid.connectToTrimbleSensor:    at Trimble.Ssi.DriverProxy.Common.Wrapper.ISensorProxy.connect (Trimble.Ssi.DriverProxy.Common.Wrapper.ConnectionSettingsProxy connectionSettings) [0x0002d] in <26049038f7f24ab670257b28d5147806>:0
  at Trimble.Ssi.DriverProxy.Common.Bridge.ProxySensor.Connect (Trimble.Ssi.Connection.ConnectionSettings connectionSettings) [0x000c9] in <26049038f7f24ab670257b28d5147806>:0
  at TrimbleSensorReaderDroid.connectToTrimbleSensor (TrimbleSensorReader+TrimbleConnectionType oTrimbleConnectionType, System.String szDeviceName) [0x00161] in <91eb2617aa6c434485af1597e21982d9>:0
TrimbleCatalystManagerDroid.connectToTrimbleSensor:  Could not connect, the receiver is not supported (1)
Additionally, when I try to connect to the SP80 in Trimble Mobile Manager using the R-Series driver the same issue happens (I can make the connection using the Spectra Precision driver).
I am not sure if maybe this is something wrong with my receiver setup or if maybe I am misunderstanding how to use the R-Series driver to connect to the SP80.
Any help would be greatly appreciated!
