Explode Corridor Surface and Breaklines
Question asked by Richard Tyndall on Jun 20, 2020
Latest reply on Jun 20, 2020 by Richard Tyndall
Below is a clip of a MSE wall model that I've created with the copy/paste table and Best & BL Across property option in the Create Corridor routine. The model is made up of 3 corridor surfaces. "Bottom of wall" includes the top of the stone leveling pad for the bottom course of block and the bottom layer of the reinforcement grid. "Top of wall block" is the second, and the "face of wall" is the third. The only surface info that makes it to the field for excavation is the bottom of wall surface. The top of wall is used to confirm the alignment is correct. The face of wall is usually not created and was only created for reference (read "showboating") purposes for this example.
To retrieve the data for the block layout, it is necessary to explode the bottom of wall surface. When this is done, the lateral breaklines for the top of the wall surface are also included with the exploded elements. Is it possible to exclude the top of the wall lateral breaklines from the exploded elements without having to a)physically delete them after exploding the bottom of wall, or b)deleting the top of the wall corridor instructions prior to exploding the bottom of wall surface?
