Problem Georeferencing Vector PDF's after initial import
Question asked by Brian Lee on Jul 1, 2020
Latest reply on Jul 1, 2020 by Alan Sharp
I have a problem where if I place some sheets from a PDF using Georef Vector PDF and exit the command to do something else, when I go back and select the Georef Vector PDF command I get the error message "The related PDF file is missing and the Georeference Vector PDF command cannot be executed". If I import a new PDF file I am then able to get the command to work and everything is fine, until the next time this happens. I'm using TBC 5.30 (build 5.30.7422.14341). This has been a recurring issue I have had on the last few projects.
