Arc/Polyline Curve Direction flipping on export to Siteworks
Question asked by Samuel Egelhoff on Sep 25, 2020
Latest reply on Sep 29, 2020 by Samuel Egelhoff
I am seeing two instances of strange curve behavior. Please see the below images. Black background are snips from TBC. White background are snips from Siteworks Emulator.
Instance 1
Correct Curve Direction - Trimble Business Center
When I check the design in the Siteworks emulator, I get the following curve.
Incorrect Curve Direction - Siteworks Design
Instance 2
TBC Design shows correctly.
vs.
The design is type: Alignment. 1632 objects in design map, mainly alignment label entities.
After I first saw the issue I started running project cleanup prior to adding linework to the design. I also went back to the base file in Civil3D and made the linework into polylines, 3dpolylines, and line/arc and I get the same result for these two curves no matter what I try. From C3D I export the linework as DXF for import into TBC.
Any advice would be welcome.
Regards,
Sam
