Problems with TBC changing Linestrings to prior positions
Question asked by Jonas Collier on May 26, 2017
Latest reply on Jul 12, 2017 by Frank Karau
I am using Trimble Business Center. After processing feature codes the line work and points look fine. I then adjust linestrings to match what is actually in the field. Some of the points are not needed so they are deleted. After the compute project function has been ran the program creates and links new linestrings to match what is left of the points from the .job file. Is there a setting that can be turned off so the adjusted linestrings hold and TBC does not change them to what it thinks is right?
Capture- Shows original linestrings and points
Capture2-  Shows adjusted data and how it should look
Capture3- Show what it looks like after the compute project command has been run
Any help would be greatly appreciated.
