Trimble Sync Manager does not change any of the data files as they are passed through the system to Trimble Access.
If you add a .dxf file containing text from your desktop to a project or job in Trimble Sync Manager you will see that it displays correctly when received in Trimble Access.
The missing text is caused because Trimble Business Center does not include the text layer when using Send to Sync. This has been flagged as an issue to the Trimble Business Center team and is being worked on.
Hi Kevin,
Chay
