I noticed this morning that TA 2018.10 & 2018.11 were removed from Trimble Installation manager. Is there an issue with those two versions? I have just set up a dozen TSC7s with 2018.11. Do I need to downgrade them all to 2018.00?
Please check Trimble Access 2018.12 Release Notes here.
Resolved issues
Upgrades of Trimble Access 2018.00 jobs containing GNSS data
We have resolved an issue when upgrading GNSS jobs from Trimble Access 2018.00 to version 2018.10 or 2018.11. When the jobs were upgraded, using either Trimble Installation Manager or automatically on the controller, Antenna Phase Center (APC) antenna heights were inadvertently being changed to another measurement method, such as Bottom of Antenna Mount . This results in incorrect antenna heights for all received RTK bases, and base and rover points using the APC antenna height measurement method, in the upgraded job. If this issue has affected a job you have already upgraded, you can manually change the incorrect antenna Measured to field back to Antenna Phase Center in the Review job screen. This was an issue only when upgrading Trimble Access 2018.00 jobs with GNSS data. It is not an issue for jobs that contain only total station data, or new jobs created using version 2018.10 or 2018.11. This issue was introduced in Trimble Access version 2018.10.
Cheers Steven
There was an issue with antenna height conversions (APC/ARP).
The new release TA 2018.12 should now be available in TIM.
