Feature Request for Alignment Editor
Question asked by Patrick L'heureux on Oct 4, 2018
Latest reply on Oct 12, 2018 by Patrick L'heureux
  • Best fit line for a profile
    • Take an existing profile and smooth it out based on criteria such as:
      • Vertical Curve Criteria
      • Holds on the start and stop of the profile
      • Whether it is a cut, fill, or doesn't matter.
    • Useful for rehab jobs
    • Necessary if we are putting machine control on the project
    • Huge time saver
  • The ability to get the cut and fill between 2 profiles, this is very useful when trying to clean up an existing profile
  • For the vertical portion of an alignment, the ability to quickly switch between elevation and slope
    • You can change the settings to allow you to enter a slope but you have to change this back and forth every time you switch the method of input
    • The match functions do not work smoothly here because you cannot use parenthesis
      • (1050-850)*-.01 - Won't work
  • PVI
    • More Visual distinction
      • My
      • My Rough Concept, above
      • Cad Example, below
    • Provide the high point and low point for the PVI
      • This is necessary when trying to maintain certain holds:
        • Catch Basins
        • ADA Ramps
