In TBC or HCE is there a way to cut off a pile string or even a 3D polyline, where it intersects a surface? I've used other packages that can.
Attached is a VCE with the surfaces and piles. The lower surface is a clay layer that I want the piles to end at. At the moment the piles extend a long way through below the surface.
Any suggestions?
Thanks in advance.
Can you send me the csv file of the drill hole points?
