Project Cleanup - Set elevation outside of range
Question asked by Patrick L'heureux on Jan 27, 2019
Latest reply on Feb 4, 2019 by Alan Sharp
I understand that the project cleanup tool has to be run a few times to purge out the nested "junk" but the "set elevation outside of range" is one area that never seems to get to zero no matter how many times you run the function. Usually after the second or third time this command is run the number of entities becomes consistent but is there a reason this will not reach zero? Is there a workflow to address this?
I see this on most projects so it is not necessarily a specific file issue.
Thank you!
