I'm currently working with a Point Cloud that has shifted vertically. On one side the vertical deviation is .02 and on the other side the deviation is roughly 7.50'. Can anyone help as to a way of adjusting this to match both ends to some existing topo on the site?
Maybe you can use "Create Scan Station" command and register again.
If it is a scale error, you can modify the scale and export and re-import.
maybe so ~~
