Processing Baselines - Failed points
Question asked by Bex Simmonds on May 1, 2019
Hiya, trying to process some PPK ground points against a Virtual Reference Station station in TBC. Half the site has processed through to a fixed solution with good precision results. However, the other half  fails and throws up the error of 'unexpected result' with no explanation as to why(these sites are in the middle of the survey time, not at the end). I have redownloaded several VRS sites to rule out this causing an error and adjusted the elevation mask and processed on both GPS and GLONASS. Wondering if anyone has any ideas as to what will be causing these sites to fail? Thanks!
