Station Offset Elevation and Template Instruction Questions
Question asked by Alan Sharp on May 1, 2019
Latest reply on May 1, 2019 by Alan Sharp
I received these questions by email overnight and I thought it worth capturing them here. The questions relate to Reporting using the Station Offset Elevation reports and also some questions about Template Instruction - Slope Field Editing. Here are the questions
  1. Is there a way to generate an excel report that is alignment based to give offset and slope for existing line work? I can create this report as shown in the screen grab but it also generates values at either points that are on the alignment or the lines I’ve selected. I would only want it to report at the specified station interval of the chainage, offset, and slope between the 2 lines
  2. When also getting it to report on the slope is there a way to make it report as a ratio instead of a percent?
  3. Similar to above, when creating a corridor template instruction of say, offset/slope in a template.is there a way to select whether the table uses percentage or ratio as the slope input?
Answers are listed below in the response
