MOUS_ICO Menu: Noise > Barriers > Absorption…MOUS_ICO Select one or several barriersThe following question appears on the command line:Enter absorbtion factor (0.0-1.0):
or
MOUS_ICO Menu: Noise > Barriers > Dialog box…MOUS_ICO Select one or several barriers in the listMOUS_ICO Dialog box: Set absorption…The following question appears on the command line:Enter an absorbtion factor (0.0-1.0):
A value between 0.0 (no reflection) and 1.0 (full reflection), telling how reflecting the barrier is.
