Use this tool to calculate the elevation for a new point elevation based on the distance between 2 or 3 reference points.
MOUS_ICO Menu: Landscape > Elevation tools > Add point elevation… MOUS_ICO Toolbar: Elevation tools:Add point elevation…
Start the function and the command prompts:
Select first elevation block:
Select one of the elevation blocks from which the new point elevation should be calculated
The command prompts:
Select second elevation block:
Select the other elevation blocks from which the new point elevation should be calculated
Specify basepoint or [Third]:
Set out the new point elevation. Use the given distances from the reference points to define position of the new point elevation or use option [Third]:type ´T` and select a third point elevation. Set out the new, third point elevation, correctly calculated on the triangular plane defined by selected point elevations.
