Novapoint Terrain Library
Add Slope Arrow
04-12-2021 12:47
Use this tool to insert a slope arrow between to reference point elevations.
MOUS_ICO Menu: Terrain > Elevation tools >
 Add slope arrow…
MOUS_ICO Toolbar: Elevation tools:  Add slope arrow…
Working procedure
Start the function and the command prompts:
Select first elevation block:
Select the first reference elevation block
The command prompts: Select second elevation block:
Select the second reference elevation block
About point elevations in Novapoint Terrain
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
