Aligning 3D Models
12-19-2016 23:11
Aligning 3D Models
Model Positioning
Model relocation is saved also on the server side, which means that when removing the model locally, model location will be remembered when downloading the model again.
You have several options to reposition a model:
  • X and Y position
  • Elevation
  • Scale
  • X, Y and Z rotation
  • Adjust the distance
Learn how to align models in:
11-14-2017 12:16
How is possible that the rotation angle in plane (Z axes) can not recognize decimal numbers?
I tried changings settings to Radians and trasforming DEG to RAD and it works. so that I guess there is some bugs in the viewer.
