Novapoint Geotechnics Library
Assumed Bedrock
04-05-2021 14:58
This tool, in the panel “GeoSuite”, may be used to insert interpreted points with attribute “B” from a selected termination code - normally “Assumed bedrock” or “StoneBoulder”.
The resulting interpreted point(s) will be available for building 3D model for Bedrock using the template “Rock” in the “Sub surface” tool in the “Modelling” panel.
The tool will create interpreted points with attribute “B” (Rock) for the selected “termination code”.
ToDo:
Note! If the model is a shared model (Quadri) - remember to reserve the Objects/Task(s) to be given as the “Selection”!
  1. Start tht tool.
  2. Specify “Name” and “Subtask of”.
  3. “Input data”: Select import task from GeoSuite.
  4. “Termination code”: Select “[4] Bedrock” (Swedish: “Berg” , Norwegian: “Grunnfjell”).
  5. “Vertical offset”: specify vertical distance in [m] (optional, negative will result in a position below the code given)
  6. Finish.
The result is now available for creating/updating the “Sub surface” for Rock.
Note!
Do not use this tool for termination code “Drilling into Bedrock” (Code 94 in Norwegian and 95 in Swedish geotechnical coding). These interpreted points are automatically created from GeoSuite Presentation and will result in duplicate interpretations for those boreholes!
It is recommended to check duplicate interpretations - these may be a result in case of multiple methods in same borehole or boreholes in the same position.
