Novapoint Bridge Library
Bridge Task
04-05-2021 13:11
Before you start working with Novapoint Bridge, you must create a new Bridge Task.
You do this in Novapoint Base, from the Modelling tab:
MOUS_ICO Menu: Modelling Bridge
Creating a New Bridge Task
Click the Bridge button in the Modelling tab.
Assign a name for the Bridge task, and a location in the process tree.
Select the road or Railway task this bridge is dependent on.
Click OK.
Key Sections
When you press the Key Sections button the dialog box 'Key Section' will pop up, which lists all the key sections in the selected Bridge Database.
Road lines
When you press the Road Lines button, the dialog box 'Road Lines for chosen VIPS Project' will pop up, which lists all the road lines for the actual Road Model (VIPS) together with the first and last station number for the road. Only one road line can be used as a reference line for each Road Model (VIPS). The is reference line usually the centreline of the road. The actual reference line is shown as the Main Alignment on the dialog box 'Novapoint Project - ID'.
