Novapoint Noise Library
Calculation Points
04-15-2021 14:08
MOUS_ICO Menu: Noise > Buildings > Calculation points…
or
MOUS_ICO Menu: Noise > Buildings > Dialog box
MOUS_ICO Select one building in the list
MOUS_ICO Dialog box: Calc. points…
or
nco: Select a building (defined in Novapoint Noise)
MOUS_ICO Popup menu: Calculation points…
In calculation points, there is some advice about where to locate the calculation points both horizontally and according to ground level.
In this dialog box, we set up/change which calculation points are to be attached to a certain building. The identity of the building is given in the title of the dialog box.
Calculation points
Calculation points
List of all calculation points defined in the drawing. A star (*) in the column Att. shows that this calculation point is already attached to a building. Calculation points may only be attached to one building. By clicking another point in the list, this will be attached to the relevant building and show up in the list Attached calculation points.
Number states the total number of calculation points defined in Novapoint Noise.
In list is the number of calculation points in the filtered list.
Selected is always blank since any selected point is immediately copied to Attached calculation points and the selection canceled.
List of all calculation points attached to this building. By clicking a point in the list, the attachment will be removed.
Number states the total number of calculation points attached to the relevant building.
Selection
From screen <
All dialog boxes are closed, and we may select one or several calculation points by selecting from the map. We get back to the dialog box by pressing <Enter>. The calculation points selected in the map, will now be added to the list Attached calculation points.
Show on screen <
All dialog boxes are closed, and all calculation points in the list Attached calculation points will be highlighted in red on the screen. We get back to the dialog box by pressing <Enter>.
Filter
Identity:
Here we select which calculation points are to be shown in the list Calculation points. The filtering by name follows AutoCAD wildcard definitions (see “Wildcard Characters” in the AutoCAD help file).
Misc.
OK
The dialog box is closed and an attachment between the building and the calculation points in the list Attached calculation points is established.
Cancel
The dialog box is closed without any changes being done.
Help
This page.
