With the function Change Point Type, you can easily change the point type of one or more points of the bridge cross-section.
MOUS_ICO Menu: Bridge Edit Change Point TypeMOUS_ICO Toolbar: Edit Change Point Type
Command prompts for:
Select a point:
Select the points, the Point Types, of which are to be changed and finish with the key Return.
The dialog box 'Point Types' will pop up. Select the desired Point Type for the selected points. All points that are selected will get the same Point Type.
You will then be asked about connection points. These questions depend on what point type you have chosen. See the topic 'Point Types and Connection Mechanism' for a detailed description.
Note: All points that are changed will have the same connection points.
