Novapoint Terrain Library
Change to Point Elevation Omitted
04-12-2021 12:26
Use this tool to add parentheses to a point elevation.
MOUS_ICO Menu: Terrain > Elevation label >
Change to point elevation omitted
MOUS_ICO Toolbar: Elevation label: Change to point elevation omitted
Working procedure
Start the function and the command prompts:
Select object:
Select the point elevation object(s) that are to get paranthesis. When finish, press 'Enter' and the selected point elevation objects will get paranthesis.
About point elevations in Novapoint Terrain
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
