Check manhole
07-14-2021 06:45
Check manhole
What
This function checks if manholes have the correct angels and height distance between pipes. It uses a configuration file with minimum values to validate.
Where
You can find the function in the dropdown menu of calculation inside the WS/Cabel ribbon:
How
This function works the following way:
  1. Click on the function
  2. You can now either select one manhole or click enter to draw a polyline around the manholes you want to check
  3. click enter when you have selected
  4. Check manhole dialog will pop up
  5. Select configuration file
  6. Now you can select the different manholes and see if they corresponds with the criterias
