The function continues an existing path. The generation method of the selected path is set as the one to be used in the continuation. The method may be changed before continuing the path.
MOUS_ICO Toolbar: Vehicle Track Analyzer - Make/Edit Path: Continue Existing PathMOUS_ICO Menu: Road > Vehicle Track Analyzer > Make/Edit Path > Continue Existing Path…
