Novapoint Road Library
Continue Path
04-19-2021 15:09
The function continues an existing path. The generation method of the selected path is set as the one to be used in the continuation. The method may be changed before continuing the path.
MOUS_ICO Toolbar: Vehicle Track Analyzer - Make/Edit Path: Continue Existing Path
MOUS_ICO Menu: Road > Vehicle Track Analyzer > Make/Edit Path > Continue Existing Path…
