Use this function to convert selected circles and 2D polylines with arcs (source objects) to a series of straight lines (more break points) and drawn as 3D polylines.
This function is also available from Novapoint tools and the modules Road, Railway, and Civil Construction
MOUS_ICO Menu: Terrain > Terrain Design > Convert Arc to Straight Lines…
Command prompts:
Select 2D Polyline:
MOUS_ICO Pick all the source objects (circles and polylines) and confim the selection
The dialog 'Convert Arc to Straight Lines' will pop up.
AC Distance determines the accuracy (number of straight lines, break points, and the curvature of a 3D polyline) with that of the arcs/circles in the source objects.
Use these options to define the elevation of the converted 3D polyline
Use this option to inherit the CAD properties of the source object to the converted 3D polyline
Use this option to delete the source objects
Execute the function with OK / Draw
Related Topics
