Use this function to convert an arc (source) into 3D Polyline with a series of straight lines (more break points). The curvature of the converted 3D Polyline with the source can be controlled with the parameter Accuracy.
> MOUS_ICO Toolbar: Elevation Tools: Convert Arc to Straight Lines
MOUS_ICO Menu: Road > Elevation Tools > Convert Arc to Straight Lines
Command prompts for:
Select a circle/arc/polyline:
MOUS_ICO Pick the source that is to be converted as 3D Polyline (program accepts only one entity)
Degree of accuracy <1.00>
KEYB_ICO Enter the accuracy number (a numeric value) that contols the closeness of the 3D Polyline with that of the source
Any value from 0.1 to 3.0 or higher can be used. For further details, refer to Accuracy in Create 3D - Line.
Related Topics
