Novapoint Terrain Library
Copy Point Elevations
04-12-2021 12:30
Use this tool to copy point elevations and slopes within the same drawing.
Note: The AutoCAD command 'copy' does not work on point elevations!
MOUS_ICO Menu: Terrain > Elevation label >
Copy point elevations
MOUS_ICO Toolbar: Elevation label: Copy point elevations
Working procedure
Start the function and the command prompts:
Select object:
Select the point elevation object(s) to copy. When finish, press 'Enter.'
The command prompts:
Specify base point or [Displacement/mOde] <Displacement>:
Select the base point of displacement. Select the place to copy the point elevation object(s). When finish copying, press 'Enter' to exit.
About point elevations in Novapoint Terrain
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations.
