Use this tool to copyclip point elevations and slopes from one drawing to another drawing. In order to paste - use function Pasteclip point elevations. Please note that the AutoCAD-command 'copyclip' does not work on point elevations!
MOUS_ICO Menu: Terrain > Elevation label > Copyclip point elevationsMOUS_ICO Toolbar: Elevation label: Copyclip point elevations
Start the function and the command prompts:
Select point elevations to copy:
Select the point elevation object(s) that are to be copied to another drawing. When finished, press 'Enter'Open the drawing where you want to copy the elevation object(s) to. Use the function Pasteclip point elevations and choose a position for the copied elevation object(s)
