From time to time it will be a need to copy the conversion rule from one task to another. For many of the tasks in Novapoint this is possible to do through the right-click menu on the task and select either:
This is also possible for Intersection tasks, but there is one thing to consider and be aware of.There should not be any Line tasks connected to the intersection task as subtasks.
Simply delete the line tasks or move them away from the Intersection task. Then the option to paste the conversion file will be available in the right-click menu.
Below is a video showing the process. We have prepared an intersection task from another project as an example.
The example file used in the video is found here.
