Use this function to design 3D objects (curbstones, hard shoulders, carriageway edge structures, etc.) along an existing line (baseline) and present the same in plan.
MOUS_ICO Toolbar: Elevation Tools: Create Parallel 3D - LinesMOUS_ICO Menu: Road > Elevation Tools > Create Parallel 3D - Lines…
Shortcut to this function:
MOUS_ICO Toolbar: Novapoint Base: object_menu
Command prompts for:
Select an Entity:
MOUS_ICO Pick a 3D Polyline (Baseline)MOUS_ICO Select the flyout menu option 3D - Lines
Select side of baseline for Kerb:
MOUS_ICO Pick a point to the left or right side of the baseline to define the direction of the object
The dialog Create Parallel 3D-Line will pop up.
Use this option for the following:
The dialog Cross-section Template will pop up with this option.
To modify an existing template do the following:
To create a new cross-section (object) do the following:
Use this option to draw the cross-section of the active template.
Select a point:
MOUS_ICO Pick an insertion point (baseline) for cross-section
Enter direction by point:
MOUS_ICO Pick a point that indicates the direction from the cross-section with the baseline (left/right side)
a, b, c, h, s, and 1 are the parameters as illustrated in the preview of the dialog Create Parallel 3D - Lines
Resets all parameters (if changed) to original values of the template Kerb
Use this option to add more break points to the parallel 3D lines in the plan for the active object.
Use this option to pick the baseline, along which the 3D parallel lines in the plan are to be drawn. Command prompts for:
Select a baseline:
MOUS_ICO Pick the baseline
Use this option to present the 3D parallel line.
For the associated functions of the lines drawn using this function, run the function object_menu.
