The function will generate intelligent point elevations from AutoCAD blocks, as well as from texts and mtexts.
MOUS_ICO Meny: Landskap > Höjdsättning > Ändra block till punkthöjder.MOUS_ICO Verktygsfält: > Höjdsättning > Ändra block till punkthöjder
Start the function. Select AutoCAD blocks and text objects. The function will search for figures and translate those into z-values. Point elevations will be generated in the dwg - they will be inserted in the insertion points of selected blocks and text objects.
