Use this function for the following:
Select Cross section under Calculations in the WS/Cable ribbon.
In the Design window go to Data and select Calculate... in the drop-down menu.
The dialogue box Calculations will pop up. This contains a list of all the trenches available in the project.
The sub-surface layers and their respective depths for different sections (stretches) along the trench route can be defined using this button. The dialogue box Sub-surface Layers will pop up.
The basic settings for calculations are to be defined on the dialog box Settings, which will pop up with the button Settings.
