Crossing Pipes
04-12-2021 16:35
Crossing Pipes
What
Here you set data for the presentation of crossing pipes in the profile part of the longitudinal profile drawing, included collision analysis. This includes:
  • Mark only existing: This function is not yet implemented, and marking this check box, will make AutoCAD crash.
  • Manhole - manhole collision: Collision analysis for manholes as well, not only crossing pipes.
  • Gap default: Gap to be used in collision analysis, both for crossing pipes and manholes.
  • Ask for gap: By marking this check box, you will also get a question on the command line whether the distance stated above is to be used or not. See Collision Analysis as well.
  • Show distance outside: By marking this check box, you indicate that the outside distance between the elements in the collision analysis is the one to be shown.
  • VM export layer: This is the prefix of the layers for 3D pipes to be exported to Novapoint Virtual Map. See Export Pipes and Manholes 3D as well.
  • Pipe Layer: This is the name of the layer for the crossing pipes in the longitudinal profile drawing.
  • Text height: This is the height of the text with which the crossing pipes are shown in the longitudinal profile drawing.
  • Text format: This shows the format of the text in the markers for crossing pipes in the longitudinal profile drawing.
  • Text X offset:
  • Text Y offset:
  • Leader marker layer name: This is the name of the temporary layer for collision analysis in the plan drawing.
  • Leader marker height: This is the height of the text with which the collision analysis is shown in the plan drawing.
  • Leader marker leader X offset:
  • Leader marker leader Y offset:
Where
The function is run from the following location:
