Cut 3D-pipes
06-28-2021 01:36
Cut 3D-pipes
This function you can use to cut 3D-pipes.
Where
The function is in the Product library tab in the Novapoint ribbon.
How
You use the function in the following way:
  1. Click on the function
  2. Click on the desired point to cut
  3. Drag the line over the pipe
  4. Click on the part you want to remove
Now, the pipe will be cut on the defined area.
