Novapoint Terrain Library
Define Areas to Calculate
04-12-2021 15:15
Use this function to store the area geometry and area ID of the areas used in the function Grid volume to file.
MOUS_ICO Menu: Terrain > Volume Calculation > Define areas to calculate
MOUS_ICO Toolbar: Terrain > Volume Calculation > Define areas to calculate
Working procedure
Select the function and a browser dialog box opens.
Type the name of the file and select folder to save the text-file.
The command prompts:
Select objects:
Select the objects (boundary lines) of the area to store. Finish with 'Enter' or 'Right click' on mouse
Startnumner <10>:
Type a startnumber. The number identifies the diferent boundary lines and will increase with 1 for each new boundary.
Give the distance between circle points to break arc's <2.50>:
Arcs will be generated into lines and the given distance (2.50m is default) determines the accuracy of the transformation.
Texthight <3.5>:
Type the text height or 'Enter' to use default (3.5)
Command: … Give return to continue to set-out number identification
Type 'Enter'/'return' or 'Right click' on mouse. The areaID and areageometry of the selected objects will be written to the specified file. The areaID is drawn in the drawing.
